Clancy Moped
As I seem to remember our watermaker needed quite a big burst of energy at the start of the cycle, so maybe work backwards to your end game on sizing of the gen.
We like it very much. I fitted a water separator in the exhaust so there’s no splashing of water overboard (the exhaust water is discharged below the waterline). It’s remarkably quiet but I admit it’s recently failed us. (A pushrod has broken). It’s a very rare occurrence (the UK importer has never ever heard of a Whisperpower generator breaking a pushrod)How do you like the Whisperpower? ... it's on my list because it has an external inverter which might make the fitting a bit easier.
Sometimes there’s no room to fit a lot of solar. We’ve got no deck space available, davits already on the stern so no big arch realistically possible and the only other space is having the solar as ‘wings’ on the rails. That space is limited.What's the intended cruising ground?
IMO a generator would never get used if you have a decent amount of solar. But obviously that depends on your consumption too.
Our Vancouver 38 Pilot certainly did, and 3 proper double cabinsA number of Vancouver 34 Pilots had a generator and watermaker fitted from new. Lots of space aft due to no quarter berths/cabins and lots of space under the deck saloon.
This postDoesn’t answer the OP query but these days no need for generator unless you have Aircon. Hi output alternators can top up batteries plus solar. Eco Tech Watermakers and similar can be DC not AC and are modular so it’s not “all busted” and high-volume AC watermakers often don’t get used enough anyway imho. Much more important important is inverter and smaller eg Aquamatic but still proper washing machine the cost of which recouped in weeks instead of distant laundromats. Any 45 footer should be enough? Big array aft and space for decent hardbottom dink hanging under. Or maybe aircon is a must? If you get a gen on a sub-55 mono it’ll be the 3000 rpm semi-disposable type surely? Why the gen?
Sounds like you are looking for a flat not a boatOn the Bav we missed a freezer, and my significant other wants a small washing machine, an espresso maker, a microwave, a hair-dryer and a vacuum cleaner.
We can tick the boxes for hair dryer and vacuum cleaner. Lots of boats have washing machines although I have a friend with one who doesn’t have a water maker which surprise…Sounds like you are looking for a flat not a boat
Read a recent sailing review which described a 45 footer as a nice entry level boat!!! On who’s planet ??Reading this, I can't help thinking about how much sailing has changed since a review of the Snapdragon 24 described her as a capable family cruiser, and a sailing boat with a generator would be classed as a superyacht.
I’d try really hard to not have a generator. They break a lot. I‘d get max solar, a hard bimini and arch covered in panels then an energy recovery DC watermaker and an extra well insulated fridge. If you can get too close to 1Kw installed power you will not need a genset.I sold my Bavaria 36 as although I had enough solar to be electrically independent, I wanted to fit a watermaker, which required more energy and I basically ran out of space to install stuff - It also got to the point where the accessories were going to be worth more than the boat. Still planning the replacement and it will be another AWB - I am prepared to go up to around 47ft but the extra size and weight are putting me off.
Hence my question, what is the smallest AWB you have come across that had a generator, a water-maker, and a reasonably large solar array while still retaining enough living space to sleep 6 adults without using the saloon?
.... and as a bonus question .... where was the generator fitted?
I'm hoping the eons of accumulated experience on these forums may be able to give me some answers - maybe even some boat suggestions.
In another thread you said you have (had?) two water makers and you showered and changed every day. How do you manage that on an extended passage without a generator?I’d try really hard to not have a generator. They break a lot. I‘d get max solar, a hard bimini and arch covered in panels then an energy recovery DC watermaker and an extra well insulated fridge. If you can get too close to 1Kw installed power you will not need a genset.
If you speak to owners of expensive brand new premium brand yachts of 45-60 foot, it is amazing how many are their first boats.Read a recent sailing review which described a 45 footer as a nice entry level boat!!! On who’s planet ??
