What I want
byron
RIP
UK -Berks
<font color=blue>On some boats you will see a sort of stainless steel rod fixed to the centre of the bow rail, this is usually guaged to the highest point of the boat. When approaching a bridge one can then see if the rod goes under, if it does then you know the rest of the boat will.
Has anyone any idea where I can get one of these?
http://www.alexander-advertising.co.uk
Renegade_Master
27 Jan 2003
Spain
Should be able to get one made up by a stainless steel man. Could have done with one of those last time I went under H'Smith bridge had a crew member on the roof peering at the underside of bridge
<A target="_blank" HREF=http://www.suncoastmarine.co.uk>Sun Coast Sea School & Charter</A>
tr7v8
30 Nov 2001
Kent
I'd have thought anyy stainless fabrictor could knock one up. Crayside Marine do what looks to be reasonable stainless.
<A target="_blank" HREF=http://www.craysidemarine.co.uk>http://www.craysidemarine.co.uk</A>
On second thoughts how about a long GRP fishing rod blank would bend easier than stainless.
Jim
I use a crew member of the correct height, has the advantage of an audible alarm
Renegade_Master
27 Jan 2003
Spain
Good idea Jim and you could put yer burgee on the end to keep an eye on the wind. (by the way seen my hint yet in other post)
byron
RIP
UK -Berks
<font color=blue> Yeh! Hammersmith can be a bugger especially on Springs even quite low boats can come a cropper there. I am sure someone already does these rods, I have even seen a spring loaded one. Mainly you see them on Brooms, maybe they do them as a special order.
byron
RIP
UK -Berks
<font color=blue>I would need a Crew Member about 8' tall then apart from which I am a single handed sailor unless you count 'OI' as Crew... see below
Hi Byron
I agree with those who mentioned the fishing rod blank system. A short Kevlar blank say 6 feet ( cut to correct length with a hacksaw) with an attached "bendy" Fly fishing tip. This would be held to the pull pit with a standard (stainless) staunchion "rod holder" which could be lowered as needed. I am sure this assembly would do the trick.
Rob
robinwdunham
byron
RIP
UK -Berks
<font color=blue>Thanks! It seems like a good idea to me too. All I need now is to get someone to make it up for me. It doesn't even need a 'bendy' at the top, I can edge forward, if it touches just back off.
<hr width=100% size=1>http://www.alexander-advertising.co.uk
longjohnsilver
30 May 2001
Byron, why not use the whip aeriel from your old decca set, if it touches it will just bend and not break.
byron
RIP
UK -Berks
<font color=blue>Thats a thought too, problem is the height is critical I must have it to exact height or may 1" or so over. Assuming the aerial is long enough (9' I think) cutting a bit off the top will make it look a bit naff.
Stingo
17 Oct 2001
Getting drunk with your daughter
Then cut a bit off the bottom and no one will notice
<hr width=100% size=1><A target="_blank" HREF=http://www.stingo.co.uk>http://www.stingo.co.uk</A> <font color=blue>- now showing at a computer near you</font color=blue>
Hi Byron!
I was trolling on E;bay and come across a million rods for sale and holders plus "wippy Fly tops" Why not have a look there worthn a try?
Regards
Rob
<hr width=100% size=1>robinwdunham
coliholic
11 Dec 2001
Cambridge
One of the dinky little wind indicator things that the dinghy sailors and other raggies use at the top of their masts? Bet there's a proper name for it. Seen a few boats on the Ouse using them. And they have the benefit of bending easily if you are a bit too tall.
byron
RIP
UK -Berks
<font color=blue>Thanks Robin but Jim is gonna fix it for me. You will have to troll through these messages to see who Jim is /forums/images/icons/wink.gif
