What grease?
brians
What is the best grease to use for winches and self furling gear? The manufacturers, Harken & Selden, seem to offer special grease at a special price! Is it really necessary?
Jools_of_Top_Cat
16 Dec 2002
Most important is to get water proof grease, general motor factor grease is not, I would have thought general marine quality grease should suffice, but you might invalidate warranty on your winches if you do not follow the manufacturers recommendation.
Julian
http://www.ukstaffords.com
samwise
6 Dec 2001
Suffolk
kalessin-of-orwell.blogspot.com
Are you sure the furling gear needs grease? Most of the kit has Delrin bearings or similar which should only need a sluice with fresh water to get the salt out.
On winch overhaul, I have found the spray grease produced by Plastimo for winches to be very effective and easy to apply. You don't need to use much of it anyway. THe Harken and Lewmar stuff is an arm and a leg and unless you are doing the Southern Ocean this year, I don't think it's worth it!
toad
31 Jul 2001
ESSEX ENGLAND
Do a search on winches there was quite a discussion last year on this subject. Most grease was thought to jam the ratchets and diesel oil seemed to be recommended for both cleaning and lubrication.
