maxi77
Are you absolutely sure all the electrical connections between the sender and the gauge are 100%. Poor connections can give all sorts of funny readings.
Thanks Peter, I'll mention that to the yard, they are planning a 'mechanical test' - any ideas what that means?
................and even too much oil; it can get whipped up into a froth by the crank and the effective viscosity drops.
How big a job is replacing it?
One problem solved is another problem found at the moment. Now that the engine senders and control panel are fixed, there is according to the mechanic:
an oil pressure drop once the engine is put through a higher rev range
This is normal for any engine as soon as the oil is up to working temperature. On a well worn engine at tickover it can drop to virtually nothing. That's the trouble with gauges. They give you something extra to worry about!
Unless you have any untoward noises I shouldn't worry. Just make sure you have sufficient oil in the engine. An old Jaguar I had with the 6 cylinder XK engine ran for two years with never more than 20psi (should have been 60) on the gauge and absolutely nothing on idling. When I got rid of it the engine was still running without problem.
