BIG.SMOKE
Active Member
Can someone please advise me on the best radio around the £50-£60 Handheld if possible as I will need to charge away from the boat.
Cheers,
B.
Cheers,
B.
If you're really going for minimum cost, I suspect it'll be a case of taking whatever's going cheap on the day. I reckon most middling to cheaper VHFs are much of a muchness anyway. You'll probably end up with Cobra; they're OK.
At about £90 each, I have two Cobras, one now five years old, the other bought last year. These are not the £50 ones, which are lower powered. The Cobra ones at £90 approx have all the channels and 1/6 watt power, and both work very well.Can someone please advise me on the best radio around the £50-£60 Handheld if possible as I will need to charge away from the boat.
Cheers,
B.
Why not stretch a few quid more and get a decent Icom.
I have an older 270 and it's brilliant.
Standard Horizon HX280e. You can pick them up for around 80 quid and to be honest, I can't think you'd want much more in a VHF Handheld.
In whcih case, maybe I'll go for a unit for a bit more £100?. Any particular brand I should look out for on ebay? Horizon?
Two radios I have used that are both sub £100 if you shop around
Midland Neptune 100
For ambitious coastal cruising in very little boats, I'm supposing that both full-waterproofing and ability to float, are basic essentials
