I can’t see any rams horns at the goose neck so you could be on the right track, a soft shackle through the reefing crinkle and over the ball might work too.Are there hooks on the sail for the reefs ?
Hi there are no hooks on the sail just eyelets and a d ring on both sides of the sailI can’t see any rams horns at the goose neck so you could be on the right track, a soft shackle through the reefing crinkle and over the ball might work too.
Do the stoppers fit through the D ring. How do you reef ?Hi there are no hooks on the sail just eyelets and a d ring on both sides of the sail
I used some bungy cord from a cleat to the horns to keep the tack cringle / reef bit in place. Made life so much easier when reefing. Doesn't look pretty close up though but hardly visible through halyard's from a slight distance.About to redesign my existing cringle and rams horn system so listening to suggestions with interest. Would like to have gone to single line but too much faff as existing system does not lend itself to that easily. Currenty the tack reef lines are back to cockpit through boom with the tack on horns. Thought about seperate tack line but just too many lines in the cockpit and needs more blocks and cleats so will probably just fit some sort of spectacle at the tack cringles that wont fall off the horns too easily. Any suggestions welcome. Only 21 footer so no massive loads to contend with but always single handed.
Guess theres two issues for me with existing setup. Its hard to get the cringle over the horn initially but then it falls off before i get tension on the main halyard. Bungee would solve the falling off problem though, thanks.I used some bungy cord from a cleat to the horns to keep the tack cringle / reef bit in place. Made life so much easier when reefing. Doesn't look pretty close up though but hardly visible through halyard's from a slight distance.
I have a short length of clear hose pushed on from one rams horn to the other underneath the boom, to stop the spectacles falling off the horns if I lose tension before hardening back up. If they do sag, the hose leads them back onto the horns when I pull up.About to redesign my existing cringle and rams horn system so listening to suggestions with interest. Would like to have gone to single line but too much faff as existing system does not lend itself to that easily. Currenty the clew reef lines are back to cockpit through boom with the tack on horns. Thought about seperate tack line but just too many lines in the cockpit and needs more blocks and cleats so will probably just fit some sort of spectacle at the tack cringles that wont fall off the horns too easily. Any suggestions welcome. Only 21 footer so no massive loads to contend with but always single handed.
