Wet exhausts
colvic
23 Dec 2001
Hants
If you have a swan neck at the discharge point and a silencer mid way in the system, do you need a waterlock?
Phil
Strathglass
Fife
Better to for two reasons
Gives somewhere for the water in the exhaust to go to when switching the engine off.
More important, most have a drain plug which allows you to drain the exhaust when winterising.
Iain
dickh
8 Feb 2002
Suffolk
Surely as long as you pump thro' a fresh water/antifreeze solution you don't need to have adrain plug? This is what I do and have never had a problem - as the waterlock is a purpose made ss one it hasn't got a drain plug.
dickh
I'd rather be sailing... :) /forums/images/icons/smile.gif
seaesta
13 Sep 2001
Whitby, Yorkshire, England
dickh is right . anti freeze solution pump thro should suffice
Frost damage comes in enclosed spaces such as engine blocks. Since the exhaust pipe will only be partly full the frozen exhaust water will tend to squeeze out lengthways before it will have enough lateral pressure to burst a strong reinforced enhaust hose - that my experience anyway. If you dont believe me try an experiment in the freezer and let us know what happens!!
Chris_Robb
15 Jun 2001
Haslemere/ Leros
You need sufficient capacity in the silencer/waterlock to allow for churning on the starter motor, which might otherwise flood the system and fill up the cylinders.
Otherwise when winterising, use antifreeze pumped through from water intake, - also is an anticorrosive, and supposed to be good for neoprene impellors.
