davidmh
I have a Buhk 20 engine in my yacht and the silencer is a stainless steel tube fabrication with a horizontal inlet at one end and similar outlet at the other. in 2002 I had to replace it as it had corroded through on one of the seams. I had a new stainless one made to similar dimensions but the seam was made it the top and not the bottom. It has lasted 16 years until now so I am well pleased, but it is now leaking water again through a weld. My question is should I get another one made in stainless or use a plastic type from the likes of Vetus. My local Buhk/Yanmar dealer says he has fitted many of the plastic ones and they give no trouble unless you have a cooling water failure when they can melt.
What advise would you knowledgeable forum members suggest, stainless or plastic.
David MH
David MH
