Wet exhaust hose replacement
New sailor
29 Jul 2020
Hi, I need to replace the starboard wet exhaust hose in my Princess 35. It is worn and leaks when the engine, a Ford Mermaid, is on. Do you think that this is a DIY job? I can see that it is a tricky manoeuvre as the hose has to be carefully threaded through some corners etc. However is it as simple as it appears. Clipping onto the manifold and then out . Appreciate comments
oldgit
6 Nov 2001
Medway
Been there done that on a P35 with a pair of 41Bs
A pig of a job.
It can be done in the water.
Ideally two of you.
Old hose was a stiff as a post.
We used a grinder to cut hose into small easy to remove sections and to cut some of the rusted clamps.
Still a pain to detach the hose from the glassfibre .
hull fitting,which also need repair and strengthening.
On mine the stainless exhaust connecting pipe had corroded and needed repair.
The new hose needs to be nice and warm as poss to make it as flexible as possible.
Make sure your new clamps will tighten up tightly on your new bit of hose.
The wall of your new hose might be thinner than the old.
Am not ashamed to admit we used a smear of CT1 to ensure a good watertight seal on all joints.
Good luck.
New sailor
29 Jul 2020
A pig of a job.
Ideally two of you.
Good luck.
Thanks for the information. I am a bit concerned about doing it. I hadn't really considered the hull section . The boat is coming out of the water to let us have a go at it. The boat was my husbands, but he died a few months ago, so my son and I are going to do it. We initially thought the leak was from the stern glands and got them repacked. Certainly they needed doing but once back in the water and testing those out we then found it was the wet exhaust hose leaking. Thanks for your comments.
simonfraser
13 Mar 2004
Sorry to hear that
if you’ve not done this kind of job b4 and are selling the boat, leave it as is and move the boat on
oldgit
6 Nov 2001
Medway
This is really a job for fit and flexible couple of folk.
From memory one of the engine hoses follows a rather convoluted route and in the case of the Volvo's has a stainless bit of pipe in the hose on order for it to change direction to avoid something else.
On mine this had seriously corroded due to the carbon in the hose pipe reacting with the stainless.
We definitely needed a small grinder to cut off a number of securing clamps which had rusted solid no amount of WD40 would shift them.
Also buy slightly more pipe than you think you need.
