New sailor
Hi, I need to replace the starboard wet exhaust hose in my Princess 35. It is worn and leaks when the engine, a Ford Mermaid, is on. Do you think that this is a DIY job? I can see that it is a tricky manoeuvre as the hose has to be carefully threaded through some corners etc. However is it as simple as it appears. Clipping onto the manifold and then out . Appreciate comments
