pcatterall
Previously I posted about restoring the gell coat on my 30 year plus Neptunian.
This was a pale blue colour but had become very mottled over the years. I thought it would have to be painted but saw the PBO article about restoring Gell coat and tested some bits
My finger ends are now worn away and the results are that:
I have had to start with 240 grit ( despite your best advice!) even 400 grit (again,not advised) was taking ages to cut away the discoloured layer even on just a small patch.
With 240 grit it takes about 5mins of hard rubbing to cover a six inch square removing all the discoloured gell coat.
I have then given that area about 1 min with 400 then 600 then 800 then Tcut then 3 applications of wax.
All in all about an hour per square foot!
It looks good though!
My question concerns the use of the progressively finer grits; I realise that the initial 'coarse' grit is having to remove a fair amount of material and that the subsequent finer grits are just removing sufficient material to remove the 'scratches' from the previous coarser treatment.
I can't see any of these 'scratches' so am just guessing the time/effort ( 1 min for a 6 inch square) used on the finer grit stages. I'm also guessing how often I change the paper as I cant really feel when its effectivness is reduced.
Any good tips ( some new finger tips would help!!) ? Am I on the right lines with my 'time theory'
I have not 'gone through' the gell coat yet!
