It’s amazing what a gale can get into if the sail is not rolled very very tightly. For winter stows we roll hard against the sheet tension all the way, then three wraps of the sheets once really tight.Spinnaker halyard wrapped several times around the furled genoa is a pretty good backup for the furling line and sheets. Takes seconds to do and could save your sail, your rig, your boat, and the boats next to you.
That's what I do all the time. As long as both sheets and furling line are made off properly, it won't go anywhere unless the sail's stretched to the point where the foot and leach are loose enough for the wind to get in, when a new genny on the insurance sounds like a good idea anywayFor winter stows we roll hard against the sheet tension all the way, then three wraps of the sheets once really tight.
Except that surprisingly often a furler rope parts near the drum and costs a sail, or moreThat's what I do all the time. As long as both sheets and furling line are made off properly, it won't go anywhere unless the sail's stretched to the point where the foot and leach are loose enough for the wind to get in, when a new genny on the insurance sounds like a good idea anyway![]()
Where do you flake it?I remove the genoa whenever I am not using the boat for more than a few days and would never leave it up when out of the water.
On the pontoon if available or as best I can on board if not. Either way the headsail comes off if Im away from the boat for any significant length of time.Where do you flake it?
My headrail goes on at the start of the season and comes off at the end. Same with the main. Like others I furl against a slight sheet tension and the sheets wrap round the sail at least 3 times. There is also some furling line left on the furler. All ines are cleated off. So far no problems after 25 plus years and the boat has seen some summer storms.I remove the genoa whenever I am not using the boat for more than a few days and would never leave it up when out of the water.
Anchored, I would have thought that several wraps of the sheets would suffice, as the boat will be pointing more or less head to wind, and if you need to vacate in a hurry you don't want the extra hassle of putting a sail on in strong wind.Now I'll take it down if we're anchored in potentially strong winds.
When we had a hoolie in Hamble at the end of October these Cape 31s were blown over. (No sails at all).Storm Barra on its way to claim some more genoas .after a fin keel yacht rotated about 20 degrees in its cradle due to a loose genoa our club has made it a hard and fast rule furling genoas must be removed prior to lifting out.
If it were up to me mainsails sprayhoods and dodgers would be removed as well in winter.
