'Welding' polycarbonate?
pcatterall
2 Aug 2004
Watching a car repair video yesterday and a guy was repairing a plastic body panel ( is that stuff polycarbonate?) He was attaching some broken brackets. He was using what I took to be a standard soldering iron and some plastic scraps.
I guess that stuff around our boats will use similar plastics so it would be interesting/useful to know which common plastics around our boats can be repaired and to learn any techniques.
Plum
6 Jun 2001
UK East Coast
It could be a modified polycarbonate or even a high strength polypropylene but either way, as Stemar said, if its a thermoplastic then yes, in theory. I've repaired a small hole in a pvc fender using a soldering iron and some white pvc stripped from electrical cable insulation. A messy looking repair but still holding pressure after 2 years.
Www.solocoastalsailing.co.uk
MystyBlue2
27 Aug 2020
Soldering iron and cable ties as the "Filler rod" works a treat. Takes some practice but absolutely do-able and fun too
duncan99210
29 Jul 2009
Winter in Falmouth, summer on board Rampage.
djbyrne.wordpress.com
You need to use the same plastic as the base material as your “welding rod” otherwise it won’t bond properly (or at all). I had a split in my water tank and tried welding but couldn‘t get the weld to bond as I didn’t have the right plastic to use. I then repaired the neck of my outboard motor fuel tank by trimming a small amount of plastic off the mounting lugs and using that as the welding material. Not pretty but still working 4 years later.
Searching for plastic welding on eBay or Amazon will find lots of kits for doing plastic welding at not overly large sums of money.
I’m not at all sure, however, if polycarbonate is up for being welded. I’ve bent Perspex by heating it gently, bending and h9lding until it cools in the new shape but never tried the same trick with polycarbonate.
rotrax
17 Dec 2010
South Oxon and Littlehampton.
I had a back handed compliment about my Oxy Acetylene welding once. Back in the late 70's, when I was a young man.
" #### me! You have done it! I recon you could weld Shit to Perspex! "
The bracket, a flimsy thing meant to hold a racing motorcycles streamling clear of the bodywork, lasted six laps around the TT course in the IOM.
Dan Tribe
3 Jun 2017
I saw a guy at a boat show making Tek Tanks HDPE fuel tanks.
He made it look so easy I thought I could do it.
WRONG! I made a lovely pig's ear. Luckily I was practising with some offcuts.
TLouth7
24 Sep 2016
Edinburgh
For rigid plastics superglue is normally the way forward. You can also solvent weld most plastics (e.g polycarbonate, acrylic, ABS, polystyrene).
Mister E
16 Nov 2015
A gas powered Hot Knife is a better tool than a soldering Iron (cheaper than electric).
These things are really intended for cutting ropes, so really useful as well.
penberth3
9 Jun 2017
You need to use the same plastic as the base material as your “welding rod” otherwise it won’t bond properly (or at all). I had a split in my water tank and tried welding but couldn‘t get the weld to bond as I didn’t have the right plastic to use.......
Also remove the dirty weathered surface - abrasive paper does the job.
billcole
30 Aug 2005
Essex UK
One combination technique is to use glue, but reinforce the repair by laying stainless steel paperclips across the break and then melting them into the plastic parts.
