Welding a Taylor’s diesel heater?
Minerva
16 Oct 2019
I “won” on eBay a fully functional and good condition Taylor’s heater last weekend. Upon delivery I noticed a crack where the chimney joins to the burner.
Before I go through the hassle of returns, is this something which could be easily welded?
KevinV
12 Oct 2021
It's repairable but currently neither fully functional nor in good condition, so unless you got it for peanuts I'd be sending it back to the monkeys.
Plum
6 Jun 2001
UK East Coast
View attachment 184172View attachment 184173View attachment 184174
They are good heaters. I have one. Certainly repairable but depends on how much you are willing to pay a competent stainless steel fabricator/welder on top of the purchase price.
rogerthebodger
3 Nov 2001
IMHO it is weldable by opening up the gap to an even width and welding in a filler rod to fill the gap and welding top and bottom. I would consider using a MIG welding set.
I would use a stainless-steel filler rod and stainless steel MIG wire
Plum
6 Jun 2001
UK East Coast
I would get a quote from a repair shop and send that and the photos to the seller and give them the choice of either paying for the repair or taking it back. If you were the only one who bid on it they are not likely to want it back. Also, you can see from the fracture, that did not happen in transit/recently.
Taylors HTD5306 Diesel Burner Case
Bouba
6 Sep 2016
SoF
I would first check that it is stainless….next I would see if the top of the piece is still good, it looks porous.
Anything is repairable…without the skill to do it yourself then it will be expensive and possibly difficult to find someone to repair it. I would look for a garage that repairs stainless steel exhaust pipes.
Mostly…I would return it
Bouba
6 Sep 2016
SoF
Even if you have a MIG welder at home.....a spool of stainless filler is remarkably expensive
