Actionmat
Hi,
I thought I'd repaired my D2, but the same fault had occurred so many times it locked me out.
So I replaced the rheostat with an 801 controller with diagnostics in the hope that it would unlock it and give me a code if there was still a problem...
To start with, some of the wire colours didn't match up with the new controller, but I'm pretty sure I've connected them in the right order.
I haven't connected the grey wire(temp sensor on the controller). The installation instructions tell me to connect it to the grey wire in the White diagnostics block, there isn't a grey wire in my loom, that block is red, brown, yellow. Any ideas which one it should be connected to?
I hadn't previously realised that the anti clockwise setting in the old rheostat was for air circulation only(it has never started the fan in that position)
So I connected the new 801 controller and tried the heat setting. It was a similar problem as before, it ran for 5 or 10 mins, then shut down(but this time with no smoke)
I then tried the fan only setting and to my surprise, the pump clicked and it ran in full blast heat. I left it going for an hour before turning it off.
I presume I've got my wires crossed somewhere?
Can anyone point me in the right direction and also tell me where the temp for the controller is meant to go?
I've printed off everything from pfjones and the varnish co., it's useful information but I've hit a dead end with this one. I'm not getting any fault codes either.
Thanks in advance
Thanks in advance
