alanwilson
My Webasto Air Top Evo 5500 works fine for a few months, then gradually starts needing several start-up cycles and eventually won't start up: the burner is clogged by hard carbon deposits & needs replacement, about every year. I've had it checked for correct CO2 emission etc.
I asked Webasto tech support some questions on 3 occasions and got different answers from (presumably) different people:
1. Is red diesel worse than white?
- Red diesel is not necessarily dirtier but will degrade over time.
2. Should the heater, like a diesel engine, be run hot at least occasionally?
- Running the heater hot periodically will assist the burn of of soft carbons; the hotter the heater burns the better.
3. If so, how should this be done, eg turn the thermostat fully up or run on boost?
- The best way to run as hot as possible is to turn the thermostat fully up.
- It is not necessarily better to run the heater with the thermostat turned fully up.
- Leaving the heater on boost will most likely not have any positive effects.
4. Any other ways of running hot?
- Try running the heater on paraffin for an hour, which will clean the inside of the heater exceptionally well.
- Only run on paraffin as a last resort to extent the life of a burner slightly.
- Using a blowlamp on the burner should indeed burn off soft carbons.
So red diesel is not the problem; the heater should be run hot; turning the thermostat fully up is the best way and is not necessarily better; running on paraffin will clean it exceptionally well and is a last resort; using a blowlamp on the burner should work.
I've also had the suggestion of soaking the burner in hot concentrated sodium hydroxide solution overnight.
Has anyone else had this problem? And found a solution that works? Or can comment on which of Webasto's contradictory statements are right? Thanks!
