William_H
Yes the rudder looks horrible (hydrodynamically speaking) No balance and very small aspect ratio. No wonder you have trouble steering in strong winds.
As said WH comes most obviously from being over pressed and heeling. Reduce sail area reduce heeling reduce WH. However the ability of the rudder to counteract WH is important. We all tend at times to sail a bit over pressed especially if only in gusts. Referring to other post about steel rudder I would say extend the rudder down to level with the bottom of the keel. Possibly cut the rudder back at the trailing edge to reduce the leverage of the rudder load. What would really work well would be to extend the rudder down lower than the keel and have area forward of the pintles. This provides balance so reduces tiller load while getting lift (turning power). This area below could be made of GRP perhaps thin that would be sacrificial in a grounding. In any case with the rudder make it wider and foil shaped for greater efficiency (more lift less drag.) ol'will
