claymore
Claymore's propshaft appears to have worn itself away by about 1mm where the cutless bearing is attached. Has anyone else experienced this?
Are you sure its the shaft and not just the cutlass bearing has worn. Easy enough task to remove the cutlass being if you can pull out the shaft. Looking at the pic of your boat on the web, it looks as if the rudder is scalloped away such that if put hard over, the shaft can be withdrawn. A standard Rubber cutless beaing is about £40 for a 1" shaft (ish)
If it is the shaft which is worn you can get it plasma sprayed up and ground back but if that is not possible you could get the rear step turned down to the same diameter as the worn area and get a "made to measure" Tufnol type solid bearing machined by ................. Forgotten his name but he posts on the web site
Found the guy. http://www.ybw.com/forums/member.php?9917-Neil_Y
If you wish, I will have a look at your bearing when I am down at the weekend.
PS. West of Scotland have metal spraying and are used to woring with marine equipment.
http://www.wose.co.uk/index.php?page=services
PPS, love your boat.
Thanks to all for your responses - food for thought and a few alternative strategies. Glad I posted!
A few years ago when the prop was changed, I poked a straightened coat hanger up the flutes and it did run smoother thereafter. You did have to remember to open the inboard side of the seal to get rid of the muck.I think that small crustacean can get trapped in the cutlass bearing and then get ground up when motoring, giving much the same grinding paste effect as mud, especially if there is some grease around to hold the abrasive in place.
If you need to pull the cutless bearing out, I have a home made puller which I used to change the bearing on my old Westerly Pentland. I have dug it out of my box of useful bits but at the moment, I cant recall how it all worked (last used about 18 years ago) so may need to have another look in the box of bits in case I am missing a bit.
The Seven Men of Ardfern have managed to get it out without drawing the shaft, which would have entailed removing the rudder, which would have entailed lifting the boat, so I feel I have got off relatively well. I am minded at this stage to see how a new bearing would do rather than start building up the shaft although clearly either that or a replacement would seem on the cards for a future winter.
Oh the joys!
Ahh
That claymore is not Claymore's Claymore, Claymore
Claymore's Claymore Claymore is in Ardfern.
All other Claymores, of which there are several, are imposters
If that Claymore is not Claymore's Claymore, Claymore, then whose Claymore, Claymore is it?
It's Gordon's. and it's for sale in Largs I think.
As per a previous private communication with the '(OP) Claymore' in question, and pertinant to the Captain Peter's coathanger post, these devices rely on a copious flow of water through the rubber grooves and Claymore forgot to mention the gungy sealant...
