Posse
How do you ensure that water does not seep in at screws or bolts going through the deck? A little Sikaflex? Or rubber washers? Or may just some suber lube grease or similar?
For fasteners going into wood then I would suggest Dolfinite
if you can get hold of it.
It is an American putty-like pate that never totally dries
thus movement stops being a problem.
Years ago I did varnish work on Ticonderoga and bits of trim
were fastened by SB screws and Dolfinite. All came out sweetly
and had been doing that job for many years without damage to them.
In the Med summer they were revarnished every 6-8 weeks
so that was a lot of unscrewing and refixing. All the slots were perfect.
Mind you this was perfectionist work.
Cheers,
Chris
Is that the same as Ralli Bondite, which is easy to get in the UK. It is used for hull/deck fixing and stays soft and waterproof forever!
