wooslehunter
Hi All,
I have a Watermota Sea Panther fitted & am considering changing the electrics.
I'd be interested in hearing what anyone else has fitted or any ideas. I have a 24v bank for starting & a 12v bank for domestic. Therefore I can't cross couple for starting if the engine bank fails. Both systems are totally independant with two alternators. The 12v alternator is bodged on and not actually fitted to the engine so any vibration movement in the engine causes stresses on the alternator bearings.
I'm considering replacing the domestic bank with 24v and using a 24->12 dc-dc converter to run the domestics. That way I can remove the 12v alternator which is bodged on anyway and also be able to cross couple for starting if the engine bank fails. I can charge from the single engine mounted 24v alternator.
What do you have? Any other ideas please?
For those who don't know - the Sea Panther is basically a Ford 1600 cross-flow block (Cortina etc) marinised & converted to diesel. Hence the compression ratio is increased & the 12v starter is run at 24v for a limited engagement period. To fit a 24v starter is a major mod although I'm surprised it was never done when the Sea Panther was developed.
Best regards,
Dave
Best regards,
Dave
