bond9007
Hi
can I pick the assorted brains of the forum on the issue of the stainless steel water tank fitted to my Liz 29. It sits nicely atop of the keel under the cabin sole and water is supplied by a small hand pump to the galley sink. Nothing unusual there but after a couple of strokes of the pump it becomes very hard to operate and it seems clear from the way it works that it has created a vacuum in the tank and is being sucked back restricting the flow of water.
It seems the original owner may have left the jubilee clip on the delivery pipe loose which would allow air into the system when the pump is operated but water may also drip out. My question is should the tank be fitted with some sort of vent pipe and if so how do I fit one now as the tank does not appear to have any spare outlets?
Do I just loosen the jubilee clip again and except that the pipe will leak a little and occasionally fall off (that's how I found out it was loose in the first place)
Regards
Regards
