Water tank filing hose size?
roger
Overwinter in Sweden, sail in Northern Baltic, liv
I am getting back into use my main water tank in the keel. Its maybe 20 gallons in size.
Whats the minimum hose size I can get away with? The usual 38 mm. size seems likely to give problems in getting the hose through the furniture etc.
I will have a separate breather.
Thanks for your ideas
<hr width=100% size=1>Roger
colvic
23 Dec 2001
Hants
Deck fillers, 38mm hose and large jubilee clips all take space and end up costing a few pennies. I've copied what a lot of continental boats have and that is a 15mm filling connection with a direct clip on/off connection to your hose pipe.
Fills very quickly and no chance of dirt etc. going down through the deckfiller.
An isolating valve inside can be a good idea.
Phil
