crown22
photo attached.it doesn't seem to want to turn.any advice of options re dismantle or replace would be much appreciated.regards stephen
Could you tell me what the numbers you give refer to? Are they generic numbers that any bearing shop would understand?These are the bearing/seal details for a 3GM 30F European engine, I'm 99% sure that the 2GM 20F uses the same pump:
Bigger (pulley end) bearing – S62012RS
Smaller (impeller side) Bearing – S60012RS
Impeller Chamber Seal – SEAL2-VITON 12-24-7 R23. This is a double lipped seal, rather than the single-lipped seal fitted as original by Yanmar; I’ve found it more effective at stopping water ingress on old shafts as it ‘seals’ against a different/unworn section of the shaft and two of them to boot
O-Ring -11 x 2.4mm – 24N0116 - I think it's called a ‘slinger ring’ and can theoretically go anywhere? I don’t know, I’ve always found it located immediately behind the seal.
The bearings listed are all stainless steel, so should survive better if/when they get any salt-water into them; I think the Yanmar ones have destruction built-in so they can sell you new ones.
The original seal is not made of ‘Viton’ but a good friend/Engineer advised that this type of seal costs only a few pence more and is better able to survive an overheat should the impeller fail.
