Sailfree
Last year after lift out rudder seemed to be continually draining water.
I think its where the GRP sheathing meets the stock as this joint must work.
What would you do? Its a Jeanneau 43DS. I am assuming the inner rudder frame attached to the stock is SS.
I can drill, drain, dry out and reglass and try to strengthen top connection but cannot help but feel it would be a waste of time and if rudder is flexing on shaft sufficient to leak it will continue to do so. I am sure that to thoroughly dry out the rudder I will have to split off one half of the GRP sheaths.
Boat is 7yrs old. Fill with closed cell foam?
Any advice?
Any advice?
