John7
We have a Navico C400M which stopped responding over Easter to the switches and started to make intermittent squeaks. The log and depth displays however were OK. On disassembly drops of water were found in a number of places, with dust over the internal seal. It had been back to Navico once shortly after being installed as it was difficult at times to read with the amount of condensation in the display.
We cleaned it up and dried it in the sun. It was reassembled using silicon grease on the, cleaned, seals and over the screw heads. Clearly the venting membrane is not up to keeping the unit dry, is this a common problem to all makes or just to some? If a problem is there any thing else, other than opening it up, drying out and resealing I can do?
