mashford
New Member
what ways can water enter engine oil is it posable for it to go through saltwater pump ?
What engine?
What symptoms, how did you notice the oil?
Sea- or fresh water cooled?
Any oil leaks?
Other leaks?
If fresh water cooled: Is it building more pressure in the cooling system than normal, bubbles surfacing with filler cap removed at idle?
If yes, check for blown head gasket.
As above are all possibilities, I'd like to add syphoning through the raw water system into the wet exhaust and filling up the engine through this.
Been there, done that. I found it quite easy to do and quite hard work to fix!
I had an agricultural engine with wet liners for the cylinders. One of which corroded due to wrong antifreeze being used. I don't know if any marine engines have this arrangement, but it needed an engine rebuild at 5000 hours.
no engine bay is dry and in cabin no leakswater dripping onto the engine and can get into the rocker cover or some other opening at the top of the engine. I had this a few years ago....I had alsorts of advice about leaking oil coolers etc turned out to be a bolt hole on top of the rocker cover had a perished rubber, a small rainwater leak was dropping onto the top of the engine and finding it's way into the oil...
okay will check the raw water pump sealYes there's plenty of larger 400hp plus marine engines with wet liners and as you say correct antifreeze selection ans concentration is essential!
There were also some smaller perkins with wet liners too, probobly still plenty around!
As for water in the oil
Water pump seals isn't uncommon on the close coupled pumos, oil cooler and the head gasket failure depending on the engines layout
have covered most in my latest engine starts imediately no problem diesel freshwater cooled heatexchangerPLEASE give us some details about your engine/gearbox, type of fuel and cooling system. Is it raw water cooled (i.e cooled by sea water) or does it have a heat exchanger?
Does your engine start straight away or do you have to churn away for a time before it starts?
Without this information it is impossible to work out the problem.
We await your reply.![]()
I'm sure the Ferguson tractor and the Perkins 4.108(?) motor has west sleevesI had an agricultural engine with wet liners for the cylinders. One of which corroded due to wrong antifreeze being used. I don't know if any marine engines have this arrangement, but it needed an engine rebuild at 5000 hours.
Kubota with water in oil.
Any Kubota/Diesel experts here?
Kubota oil in water
Kubota oil in water - Yesterday's Tractors
