ShinyShoe
5 litres - doesn't accomodate 2 x 500ml cans ... ;-)
This isn't quite true as the peltier device itself has a pretty low thermal conductivity; if it didn't you would have a lot of back-flow of heat from the hot to the cold side when it was on, reducing performance.As the article says, it is a CONTINUOUS drain of an amp or so. I can understand why - to simplify, a Peltier effect device pumps heat from the cold box via a highly heat conductive path to a hotter environment. As soon as the current goes off, that highly effective conductive path simply allows heat to travel back from the hotter environment to the cold box.
MY idea was to use my 100 gallon fresh water tank ( which has a large surface area on the underwater hull) as the heat sink ( no holes in hull). I will appreciate comments on using the fresh water tank.
