stevenhumphrey
Active Member
just some infor on water for the trip, for us guys?girls yet to do a hop of this length.
Katadyn 40E
12 or 24 volts DC
RELIABLE Water Supplies
The Power Survivor 40E allows you to cruise further and stay longer without worrying about your water supply. And has the added feature of being Manually operated if necessary,
The ONLY one in the World.
Simply remove 4 motor fixing bolts and fit Handle. (Supplied)
With this superb machine there are no foreseeable circumstances when you cannot make water.
Compact: Extraordinarily compact, the 40E can be installed in the nooks and crannies otherwise unusable in many yachts.
Simple: The 40E contains 40% fewer parts than its popular predecessor, the PowerSurvivor-35. Simplified construction and rugged design make the 40E remarkably easy to install, operate and maintain, and needs no specialist knowledge.
Efficient: No other watermaker draws so few amps. Using only 4 amps it can run for extended periods of time on alternate powers alone Super Quiet and Gentle.
Durable: Rock solid and built to last. The heart of the 40E is the rugged stainless high-pressure pump. Armed for the rigors of the marine environment, this watermaker is built to last. We're so certain, we've covered it with a superior warranty: 3 years on most components.
PERFORMANCE SPECIFICATIONS
Power Requirements 12-volts DC(draws 4 amps)
24-volts DC (draws 3 amps)
Water Production 1.5 gallons (5.7 liters an hour)
Weight 25 lbs. (11.33 kg)
Dimensions: Pump Height: 6.75" (17.15 cm)
Length: 16.5" (41.91 cm)
Width: 15.5" (39.37 cm)
Pre-treatment Filter Length: 12" (30.48 cm)
Diameter: 6" (15.24 cm)
Feedwater Flow Rate 20 gallons (75.7 l)/hour
Salt Rejection 98.4% average (96% min.)
*** Katadyn Watermakers come with a complete installation kit ***
Accessories & Parts
SEAL REPAIR KIT Euros 120.00
Extended Cruise Kit
Includes items needed for regular care and periodic maintenance and/or storage.
• 1 x Acid Cleaner
• 2 x Alkaline Cleaner
• 6 x 30 Micron Prefilters
• 1 x Repair Seal Kit
• 1 x Biocide
Euros 395.00
Preventative Maintenance Package
Includes the contents of both Silt Reduction and Extended Cruise Kits.
Recommended for all long voyages.
• 1 x 1 Amp 12 Volt Booster Pump
• 2 x 5 Micron Prefilters
• 1 x Acid Cleaner
• 1 x Biocide
• All Necessary Fittings
Euros 1,095 .00
KATADYN Pricelist Data Sheet Installation and Operation Manual
KATADYN 40E 12 volt Euros 2,700.00 + VAT
Email: sales@sunshinemaritime.co.uk
Tel/Fax: (0) 870 240 6275 (Please note,this is often on divert please be patient
"The Best Thing Since Rain"
Back to index</A.< strong>
LINKS www.sunshinemaritime.co.uk
www.sunshinemaritime.com
www.dieselcraft.co.uk www.hpwatermakers.co.uk
Water, Water Everywhere
A couple of years ago, I spent 10 days cruising the Grenadines on a 51-foot boat with nine ladies and 300 gallons of water at the tail end of dry season, when the islands are browned and scorched. At the chart briefing, prior to the trip, the charter company guy told us that there would be only two places to get water once we left St. Vincent. We could fill up in Union Island and maybe in Petit Martinique, if they had rebuilt the dock damaged by Hurricane Lenny. He wasn't sure if they had, but he did know that wherever the topping off would happen, it would cost at least 25
cents the gallon, or 75 dollars for a refill. Seventy-five dollars for water! Holy cheapskates! That could pay for several really nice meals, a good pair of shoes, or five tanks of gas for my car at home—that is if we ever needed to take on more water. The ladies on my boat had come to experience and learn something about cruising from me and here, by gum, was incentive for the perfect lesson.
Early on in my sailing career, I had learned about water conservation from a severe and, some would say, an overly obsessive teacher. This was my father; in the early ‘80s—the days when sextants were still used more than unreliable SatNavs. Back when many cruisers were still distrustful of gadgetry and cruising boats were fairly simple and functional, he bought his first boat for our first family cruise that took us from England to New York via the European Coast, the Canary Islands and the Caribbean. Always one for lectures, temporary suffering, and lessons learned the hard way, he began drilling us about the many aspects of the sailing life from the time we first set foot on deck. One of his main issues was water. All the way down the European coast, where all we had to do was turn left and head for any harbour for more water if we ran out, we still had to practice going without to be prepared for the potentially desperate times that lay ahead.
Among all the uses for salt water we discovered and explored, figuring out how to calculate a potable ratio of salt water to fresh water for boiling pasta was invaluable on a boat where both the failed freshwater pump and the galley hand pump that wouldn't prime easily went purposely unrepaired to facilitate frugality. We could drink as much tea and eat as many noodle soup as we wanted, but suggesting a weekly freshwater rinse for the hair would have been received as a request nearly as ludicrous as asking for ice cream on a boat with no refrigeration. What, are you kidding? You want to waste freshwater to rinse your hair when we are surrounded by the ocean? Keep dreaming, kiddo. And dream my sisters and I did with our long hair, until we arrived in harbours with public showers.
Then came the Atlantic crossing, the big one where we could be at sea for weeks, even months if we got dismasted, said my father almost hopefully, eager to meet a real challenge. He filled the fuel and water tanks while my sister and I made sure we had enough books to last forever because with my Dad, we couldn't rule out that possibility. The trip from Gran Canaria to Guadeloupe ended up taking a modest 24 days because of some long-lived calms and strict conservation rules that applied to fuel and engine use as well. We children learned to abide by my father's strict adherence to self-discipline, but not without lots of laughs at his expense. I can't remember how many gallons that boat carried, but she was a 38-footer designed for long-distance cruising, so the tanks must have been fairly substantial, yet we even had to brush our teeth in salt water for the crossing. When we got to Guadeloupe, those tanks had been barely touched; there was still enough for a Pacific crossing.
There was no end to the ribbing he got for his extreme ways, but two years later, when I left on a circumnavigation on my own boat, I took some of these ways with me. With only 40 gallons in tanks and 10 gallons in jerry cans, I managed crossings that lasted up to 50 days at the longest, and, thanks to the ocean, was never deprived of the means for cleanliness. My cat and I never went thirsty, either, but several times, the Swiss stockpiling genes kicked in and I became concerned enough to rig a bucket underneath the main boom during heavy rains to increase the already healthy safety margin and my peace of mind.
Years later, on a week-long charter in Thailand's Phang-Na Bay, I skippered a boat for a group of women. There was nowhere to fill the tanks during the trip, there were no jerry cans aboard for lugging any additional water, and I hadn't worked enough yet in the capacity of captain to be able to command anything near the authority my father had wielded over us. I wanted all the ladies to be happy, and when my feeble requests for bathing and doing dishes with salt water went largely unheeded, I just gritted my teeth and cringed every time I heard the water pump go on until, on the last day, there was nothing left to pump.
The ladies weren't being disobedient; it was more than that. It was a combination of me not feeling self-confident about my knowledge to assert it strongly enough and the inability of these ladies to radically ratchet back on the consumption of something we take for granted and that must be unlearned. The Swiss Army and my father's years of independent travelling in desert regions had taught him how to ration, how it's always better to learn how to live with the minimum than to run out. Without becoming quite as extreme as he—I have never made anyone brush their teeth with salt water—I also had learned how bathing and doing dishes might be nicer with freshwater, but the salty stuff works very well, too. I can't say I would have known this, though, without having spent so many years at sea, cruising.
After my experience in Thailand, I never wanted to run out of water again, least of all with nine women on a boat. So the Grenadines, a new and more mature version of me stood at the helm. Cruising isn't just about navigation, sail handling and engine maintenance, I told them. It's a way of life that uses available resources and an economy of living that we rarely get exposed to on land, especially in the US. I showed them how wonderfully some soaps will lather up in sea water, how great it is to be able to sit on the aft swim platform to soap up, then to jump overboard and stay in the warm tropical water for as long as needed to really get clean, without standing in a tiny head, using a trickle and feeling guilty because the electrical pump is a loud tattletale and I have good ears. Then, with the deck shower, I allowed them to rinse off the salt water at the end—without the encumbrances of soap, this never uses much more than a pint. Best of all, I told them, with a bath off the stern, one never has to wipe down a stinky head, one of the most unpleasant things you can do immediately after getting clean.
They also learned how resilient dishes, cutlery and pots and pans can be, how these things don't even need a freshwater rinsing if they're dried properly. The initial response was pretty doubtful, but by the end of our 10 days, the biggest sceptics were washing and drying dishes with buckets full of water without a second thought. On our last day, except for the one woman who had never put her toes in the water, we were all jumping in, lathering up, jumping back in to get rid of the soap and lightly rinsing off with a stern shower as if it were the most normal thing to do, which it is when you are surrounded by beautiful, clear, and warm ocean water. We returned to the dock having emptied only three of the four water tanks, well within the safety margin, not only with clean dishes, clean decks, and nine clean women, but $75.00 ahead of the game.
KATADYN SURVIVOR 06* The world's smallest desalinator
FACT SHEET
PRODUCT CHARACTERISTICS
Technology: Reverse osmosis
Salt rejection: 98.4% on average (95.3%
minimum. The desalination degree
effect depends on different influence
factors such as pressure, throughput
and the quality of water)
Flow: 0.89 l/h +/ 15%
Weight: 1.13 kg
Dimensions: 12.7 x 20.3 x 6.4 cm
Guarantee: 1 year
Material: Pump: Stainless steel, plastics.
Membrane approved by the US FDA
(Food and Drug Administration)
Article No.: 8013418 with biocide
8013419 without biocide
* Earlier PUR Survivor
FACTS
• Handoperated desalinator for 16 people
• Optimum pump frequency: 40 pumps per minute
• Approved by the U.S. Coast Guard and used by army troops worldwide
• Prescribed equipment for "AroundAlone" sailing regatta
PRODUCT CHARACTERISTICS > BENEFITS
• The world's smallest desalinator > find space for it anywhere
• Provides 0.89 litres of water per hour > ensures survival in an emergency
• High energy efficiency > pumping does not require much effort
• Can be operated manually > not dependent on electricity
• Durable design > extremely reliable and long life
• Weighs only 1.13kg > ideal wherever minimum weight is an issue
SHORT PROFILE
salinator. Emergency tool
for inflatable liferafts and
overboard bags. For 1 to
6 people. Also suitable for
sea kayaking.
1
FACT SHEET
REVERSE OSMOSIS
To remove dissolved salts from seawater with reverse osmosis, part of the salt water is filtered through a semipermeable mem
brane. Only 10% of the water passes through the membrane. The remaining 90% flow past the membrane and at the same
time cleans the membrane (selfcleaning effect). The small size of the "membrane pores" ensures extremely pure drinking wa
ter, but extremely high pressures must be generated normally 55 bar.
Reverse osmosis is used worldwide to obtain drinking water, e.g. in the semiconductor industry and in medicine.
KATADYN'S PATENTED ENERGY RECOVERY SYSTEM
The Katadyn Energy Recovery system takes advantage of stored energy in the high pressure reject water that is typically wa
sted. The pressurized reject water is recirculated to the back side of the piston to aid the next stroke. This energy is kept in the
system, resulting in less work to achieve fresh water.
APPROVALS
Approved desalinator as defined in the 1983 conditions of the Safety of Life at Sea Convention (SOLAS).
USA
United States Coast Guard (USCG) license no. 160.058/7/0
Federal Aviation Administration (FAA): fulfills Federal Aviation Requirement (FAR) Section 135, 121
CANADA
Transport Canada Coast Guard: T.C. 208004001.
Aviation: in compliance with Air Navigation Order (ANO) and Series 11, No. 8 Schedule 111, 1(b)
Katadyn reserves the right to modify products
Katadyn Produkte AG ¦ Birkenweg 4 ¦ 8304 Wallisellen ¦ Switzerland
Tel +41 1 839 21 11 Fax +41 1 830 79 42
info@katadyn.ch ¦ www.katadyn.ch
2 A03
am not to sure which one i will go for yet.
KATADYN SURVIVOR 35* The most powerful desalinator for emergencies
FACT SHEET
Salt Rejection: 98.4% on average (95.3% minimum.
put and the quality of water)
Flow: 4.5 l/h +/ 15%
Weight: 3.2 kg
Dimensions: 14 x 56 x 9 cm
Guarantee: 1 year
FDA (Food and Drug Administra tion)
Article No.: 8013433 Standard
FACTS
• Handoperated desalinator for up to 20 people
• Optimum pump frequency: 30 pumps per minute
PRODUCT CHARACTERISTICS>BENEFITS
• Compact dimensions > find space for it anywhere
• Provides 4.5 litres of water per hour > ensures survival in an emergency
• Weighs only 3.2 kg > ideal wherever minimum weight is an issue
SHORT PROFILE
Survival tool and extra
source of fresh water for
sailing and sea kajaking.
Provides enough water for
groups of up to 20
people.
1
FACT SHEET
REVERSE OSMOSIS
APPROVALS
USA
United States Coast Guard (USCG) license no. 160.058/6/0
Federal Aviation Administration (FAA): fulfills Federal Aviation Requirement (FAR) Section 135, 121. Fufills Intent of Advisory
Circular 12047
CANADA
2 A03
-------------------------------------------- /forums/images/graemlins/laugh.gif
Katadyn 40E
12 or 24 volts DC
Accessories & Parts
Extended Cruise Kit
• 1 x Acid Cleaner
• 1 x Biocide
Euros 395.00
• 1 x Acid Cleaner
• 1 x Biocide
Euros 1,095 .00
FACT SHEET
Weight: 1.13 kg
Guarantee: 1 year
FACTS
SHORT PROFILE
sea kayaking.
1
FACT SHEET
REVERSE OSMOSIS
APPROVALS
USA
CANADA
2 A03
FACT SHEET
Weight: 3.2 kg
Guarantee: 1 year
FACTS
SHORT PROFILE
groups of up to 20
people.
1
FACT SHEET
REVERSE OSMOSIS
APPROVALS
USA
Circular 12047
CANADA
2 A03
