Watchet..... again.
Rustyknight
13 Aug 2003
Looking at all the crane activity just inland, I'd say it was to do with the new nuclear reactor being built at Hinkley Point, with Burnham on Sea just visible in the far distance.
graham
They used the biggest crane in the world building Hinkley Point power station. It is called "Big Carl"named after the father of one of the directors.
From that angle I'm sure Weston Pier would be hidden behind Brean Down which is the long headland at the S.W. end of Weston Bay
shirazchaz
21 Jul 2019
Back inthe late 1970's I used Watchet as a port to load charter vessels with about 1,000 tonnes of animal feed for Libya! The facilities were "similar" to those at the other end of the trip!
NotBirdseye
13 Apr 2019
Wales
Presumably this will set the precedent for other berth holders to copy which will finish the marina financially. Could the Watchet boat owners association take it on as a cooperative?
I believe the quote for doing a full dredge was £250,000 so that right there is the minimum people would need to gather. With boats leaving all the time and I think council restrictions hindering the process... it's hard to imagine a way forward for this unlucky marina.
NotBirdseye
13 Apr 2019
Wales
It's not so much worse as forcing their hands to actually do what they said they were going to do as part of their lease and that means dredging (which they have been reluctant to do and I do understand why but those were the terms).
Yellow Ballad
10 Oct 2013
Sundance, Bristol Channel
Well it looks like the council are going to get this back in their hands and I can't see them getting it any better? I don't think I can blame the leaseholders, I think they've been sold a duffun.
I really want to make the trip across, for the last 4 years I've planned it but haven't because it's got progressively worse. I'm not actually sure I can get in at HW and back out again now?
I Imagine the fact it's not a massively important port (with Cardiff the other side) means the investment isn't top of the pile, I know of land folk that are turned off by visiting by car because it's so run down.
Maybe knocking the sill out a few metres and boats being able to get in and out from 1/2 tide will make the difference, I'm a 1.6m draft whose happy to sit in mud.
sarabande
6 May 2005
The council (SWand T) are the authors of the problem. They sneaked a "Clear out the mud" clause into the contract, and then colluded with the Environment Agency to prevent the mud being swooshed out in the early years when there was a half decent depth of water and therefore some power in the outgoing tide.
There used to be a Watchet Fishermens Cooperative that knew about the flows in the harbour but I think it ( was ? ) disbanded when the marina started up. Mud has always been a problem in the area, hence the development of the small fishing boat called a Flatner which could take the ground and not tip over.
NotBirdseye
13 Apr 2019
Wales
Completely granted but I'm pretty sure maintaining the marina is pretty standard contractual stuff and surely dredging would be under that?
PCUK
29 Jun 2005
Westleigh, Nr Tiverton, Devon.
In the grand scheme of things £250,000 seems a small price to pay to end the marina's problems. If only my Premium Bond would come up!
oldmanofthehills
13 Aug 2010
Bristol / Cornwall
The Council bodged up the marina build by splitting it in two to please the non-existant fishing fleet, and then having the stream diverted so it flows through neither half they stuffed the marina from the word go.
I can get into marina with 1m draft but need to makesure i am on hammerhead if I need to get away with sill opens, to get the rising tide to Uphill.
Practically anyone can get into outer harbour if they dont mind scaling 20ft ladders and sorting out very long mooring lines but there is not much space on the wall
Birdseye
9 Mar 2003
s e wales
Watchet harbour used to have a bad build up of mud before the marina was built. I remember it well having frequently ploughed my way to a mooring. There was a stream flowing though but it wasnbt a big one and it left a gulley in the middle rather than clearing all the mud out.
The design of the marina with a cill made the problem far worse. Bristol Uni did some work on it and found that every tide was depositing an average of 80 tonnes of silt with the inevitable result that the operators would have a fequent dredging need. Simply not viable financially.The mooring income doesnt cover the costs. I am really surprised at the council notice - I would have thought they would avoid this dead duck like the plague.
