NorthRising
Hi does anyone have a copy of the original instructions for one of these? Deployment looks very simple. On the back there is a a small screw, and I wonder what its function is... ?
Looks like a lubricating point to me.Thanks, here is a photo of the back, screw highlighted in red.
Now that is ingenious ?With ours we have a cone made from the top of a tonic water bottle, or similar, with a split down it. To recover the spinner we slip the plastic cone over the line to the spinner and let it slide down the line to cover the spinner. This stops it spinning and it can be recovered without the line getting all knotted up.
Sorry for delay. Have now found the instructions for my Wasp trailing log but it appears to be a different model to yours as there is no small screw on the back. My instructions hereHi does anyone have a copy of the original instructions for one of these? Deployment looks very simple. On the back there is a a small screw, and I wonder what its function is... ?
Thanks for posting that. I've been wondering how to oil the 50 year old Walker log that I inherited from my dad. The answer: don't!
I last used it 2 years ago. It read within 7% of the SOG and distance over ground on my GPS and, though there's no tidal current in the part of the Med I was in, there can be an ocean current of a knot or more. I ought to do a calibration table one day, running up and down reciprocal courses.
A good additional tip is to make sure that you pass the end of the bit you're paying out round a stanchion. If you slip with our fingers as you pull in the ever twisting line, you've got a chance to grab the tail...Looks like a lubricating point to me.
Assuming it's like a Walker ...
* To deploy, connect to the log then start paying out from the log end until it's all out, forming a loop in the water, and th espinner is still beside you. Lob the spinner in, well clear of the rope.
* To bring in, unclip from the log and pull in the spinner while paying out the free end you just unclipped. The cord will be twisted as you bring it in but untwists as it goes out. When you have brough in and paid out the whole line, so the spinner is in your hand, haul in the line.
Sounds complicated, but in practice dead easy and takes 30s tops each way.
It's a great tip, but I always used to end up losing the funnel I've made and ended up reverting to plan AWith ours we have a cone made from the top of a tonic water bottle, or similar, with a split down it. To recover the spinner we slip the plastic cone over the line to the spinner and let it slide down the line to cover the spinner. This stops it spinning and it can be recovered without the line getting all knotted up.
.Walker Logs DO need oiling. Mine has a special oil can and a little hole in the face to drip the oil through.Thanks for posting that. I've been wondering how to oil the 50 year old Walker log that I inherited from my dad. The answer: don't!
I was given a Walker log some years ago and included with it was a section of plastic bottle as you described. Now I know its purpose. Thanks!With ours we have a cone made from the top of a tonic water bottle, or similar, with a split down it. To recover the spinner we slip the plastic cone over the line to the spinner and let it slide down the line to cover the spinner. This stops it spinning and it can be recovered without the line getting all knotted up.
Many thanks for looking and for the instructions, even if they are for a different model. Here is hoping that 2021 sees the virus under control and an opportunity to use the log on some passage making.Sorry for delay. Have now found the instructions for my Wasp trailing log but it appears to be a different model to yours as there is no small screw on the back. My instructions here View attachment 105174
www.solocoastalsailing.co.uk
Yes. On a Walker like the one we carry and as photographed above, you open the face and just turn the hands back to zero. They’re a grip fit on their shafts and you can twist them easily with your fingers.Hi, is it possible to reset the trip counter on one of these please? I've just acquired one.
Assuming you are referring to a Wasp log, on my Wasp Globemaster log it is not possible to reset the distanceHi, is it possible to reset the trip counter on one of these please? I've just acquired one.
Hi, It's an S10. There is a screw on the back of the case under the rubber cover.Assuming you are referring to a Wasp log, on my Wasp Globemaster log it is not possible to reset the distance
Sorry, different model to my Wasp Log, mine does not have that on the back........Hi, It's an S10. There is a screw on the back of the case under the rubber cover.
Not possible on the Wasp log, as far as I know. I looked into it for mine but it seems that a low speed drill and looooooots of patience would be needed.Hi, is it possible to reset the trip counter on one of these please? I've just acquired one.
