Warning to Jeanneau Owners
Irish Rover
5 Feb 2017
Türkiye
From an Irish news site today
"Irish owners of a type of high-end French-made yacht have been warned of a risk of sinking, due to problems affecting a part in the hull.
The warning was issued by the Department of Transport this morning, and concerns three models of Sun Odyssey boats made by French boatmaker Jeanneau.
All the affected boats were built between 2020 and 2022 and all are equipped with a bow thruster device that deploys out of the hull and below the water line when in use."
Bouba
6 Sep 2016
SoF
I think it’s good they are doing a recall.....cars are recalled all the time...often for some extremely serious safety concerns... and the research and development costs involved far outstrips yacht production...even at giants like Beneteau/Jeanneau
Tranona
10 Nov 2007
"Because the safety of our boats is an absolute priority, we have decided to reinforce the thruster flange on these hulls to prevent the occurrence of seepage."
But not enough of a priority to construct it properly in the first place 🙄
It is rare for a manufacturer (of anything) not to make the odd error. It is how it deals with the consequences that is important.
dunedin
3 Feb 2004
Must be a major hassle if impacted, as instruction is not to use the boat until fixed. Insurance wise could be tricky if ignored. But unless boat is adjacent to a Jeanneau dealer with capacity to repair, that could be the Sumner cruising stopped dead.
And what do you do if hundreds of miles from a Jeanneau dealer - or even a boat lift?
Bouba
6 Sep 2016
SoF
That is bad…how are you supposed to get it to them ? Or will they see you ?
lustyd
27 Jul 2010
You’ve obviously never dealt with Jeanneau dealers. If you’re not buying a new boat then you’re dead to them whether you’re 5 miles or 5000.
This wouldn’t be a problem but Jeanneau don’t deal directly with customers so they’re the only option.
Bouba
6 Sep 2016
SoF
I can report that their sister/parent company Beneteau are exactly the same
sawduster
4 Aug 2020
The odd error is understandable and I'm sure their response is commendable now that they've been found wanting, but bow thrusters are not new or uncommon technology. Was it a design fault, a construction fault, a fault with the thruster supplier?
It would be interesting to see what the root cause is - this article , Bow thruster weak point: Two accidents show how important correct installation is though barely readable without paying - seems to indicate a fault in the construction process which is concerning at a business which you would expect to have robust QC processes.
The fix appears to be take it back to Jeanneau for them to stick some adhesive in the gaps where there should be laminate, or add laminate it yourself. Doesn't inspire much confidence.
Bouba
6 Sep 2016
SoF
It seems they were the swing down style of thrusters.... I would imagine that there is considerable force on the bracket...perhaps it wasn’t reinforced enough
ylop
10 Oct 2016
The statement is spectacular:
As a precautionary measure, we would also like to advise you that you must stop using the boat until this reinforcement has been carried out.”
Well which is it - advisory precaution or must?
While waiting for this operation to be carried out as soon as possible, it is necessary to:
  1. Inspect the thruster area for water or signs of water ingress,
  2. Check for the presence of water when the thruster is retracted. In case of detection, it is essential to ensure that the thruster is closed and then to disconnect the thruster, to stop using the boat and to contact your dealer to carry out this reinforcement as soon as possible.”
So it is only necessary to stop using the boat if ingress is detected?
It’s like the technical department wrote something and then the marketing folks tried to make it would better!
lustyd
27 Jul 2010
One failure in 24 years though would suggest the design was good enough in most circumstances. Given the age of the boats it's entirely possible it was an owner modifying something so if they found a genuine fault I think that's impressive
Even so, I'd expect it to be in a watertight area at the bows. Sinking seems quite drastic even for complete failure of a bow thruster. Hopefully more details will emerge in future.
Let's remember that until this incident we all thought Jeanneau didn't have this issue so let's also not rule out the same issue being present on other manufacturers. If this were aeroplanes the other manufacturers would all check and confirm they don't have the issue, but it's boats so it's on the owner.
Irish Rover
5 Feb 2017
Türkiye
Age? Affects boats produced between 2020 - 2022,
