snowbird30ds
Can someone please tell me the thread on a volvo 41a oil pressure sender.
Volvo VDO senders only work with VDO gauges , believe me I’ve been there , they don’t work with Durite or Faria gauges , I doubt they work with some of the Chinese stuff on eBay either .Thanks guys, I have rebuilt my dash with Kus gauges from asap and couldn't work out why the oil pressure showed half what it should , I'd got 5 bar gauges but the vp one was a 10 bar one, yeah that'd be why Doh!, 5 bar is a better range for 30+ year old engines so I'd rather change the senders to suit.
I'm a bit confused as to why that should be as I've just done a little experiment on the bench with the original VP oil gauge and some resistors, 10ohm and it read bottom of scale, 100 ohm and it was centred, 180 ohm and it gave full scale, exactly what I'd expect to see any euro range gauge do so the senders should be fine with any euro gauge.(except the fact that mine are 5 bar not 10 bar so only read half the actual pressure)Volvo VDO senders only work with VDO gauges , believe me I’ve been there , they don’t work with Durite or Faria gauges , I doubt they work with some of the Chinese stuff on eBay either .
Same here on a TAMD60CWhe I had this problem I bought a sender and gauge set off ebay for twenty somthing quid and a thread adapter.
Worked fine.
