gordmac
I (and others) have been working on various problems on a friend's boat, twin KAD 44 on outdrives. Major issue is the starboard control lever in the wheelhouse isn't recognised and does nothing, the one on the flybridge works fine. When you press the station button in the wheelhouse the port red light is solid, starboard flashes. Press the flybridge one and both are solid red and work fine.
Swapped the control lever connections, fault stays with starboard. Someone else swapped flyybridge and wheelhouse controls, fault stayed put. Connections we can get at cleaned but they looked ok. Both wheelhouse levers resistance varies with lever position but one resistance range is quite different to the other. The wiring for the station ecu things were swapped but no change. Tried another edc controller but that made no difference.
Any ideas how to solve this greatly appreciated.
