Volvo TAMD60C - Fresh Water level increasing
superheat6k
10 Jan 2012
South Coast
Having noticed for the last few runs a small qty of engine coolant in the bilge I have been looking for a leak on one of my TAMD60C's but can't find one. I have also notice the water levels have not been dropping to account to for the obvious loss.
However this morning I have found the stbd has filled its header to the brim.
Am I right to assume this must be due to a small leak at the seawater / freshwater heat exchanger ?
If so if this likely to be a simple O ring seal problem, the rubber gaiters that support the insert, or (and I hope not) a b*gg*red insert.
Any help on this one would be appreciated.
Is there a test to check for seawater in the fresh circuit ? With the toxic glycol present on the fresh I am reluctant to do the old fashioned taste test.
Is it on the engine that warms the hot water tank? If so I'd say your coil in the tank has split pressurising the engine cooling system. I doubt the sea water side would exchange sides as its running pressure is lower than the fresh water side.
No, it is the non calorifier engine.
I have removed the insert and found it is weeping when I fill it with vinegar.
So either a new insert or hopefully a repair at Wessex Radiators.
If the seawater pressure is higher than the freshwater pressure would this suggest partially blocked injection bend jets ?
