aviator
I have Volvo TAMD75 EDC engines and have had a history of problems with the upper helm but not the lower helm engine controls.
The boat was new in 2004 and AFAICS in 2006 Volvo fitted SPM units (Signal Processing Module) which were a March 2006 retro fit for TAMD74 and 75 engines EDC only.
The fit kit was Volvo part number 3887834 and included the SPM unit and a piece of foam for the relay box fitted inside the cover.
Does any of this ring a bell as I would like to find out the background to this unit whose purpose seems to be processing the throttle signals at each control station and logging the last 15 run cycles (all this from the installation instructions I have)?
They were clearly looking for a problem and it may be related to voltage drops due to connector problems.
Thing is that I have a problem where intermittantly the upper helm drive disconnects and the engines go into limp home mode. Throttles to neutral and re-engage drive and back to normal. Could go in 5 minutes or 5 days.
I am looking for information which could assist in finally fixing this problem. FWIW Volvo have been supportive but seem to have run out of ideas.
Any information much appreciated.
Oh and the mustery is that I looked at the wiring for the upper helm and could not find this SPM unit which I know was fitted. I have not looked at the lower helm since this is much more difficult to get at ;-) The instructions say that 2 SPMs must be fitted, one to each control station, so if there is only one fitted that must be a problem.
TIA
TIA
