Volvo seawater filters
Megaboat
23 Jan 2022
Hi, I have a pair of volvo KAMD44P EDC and seem to have problems getting the seawater filter lids to seal well.
On previous boats I found that when I removed the screw top the inner lid would be held down by the vacuum caused by the seal as soon as I lifted one edge the seal would break and the filter empty back through the seacocks .
On this boat I cannot seem to get the same seal and on occasions the pumps are not drawing water through properly and I have remove and reseat the lids.
Any thoughts from the assembled wisdom?
Despite my fitting a new sealing gasket mine still failed to allow a proper flow and caused over-heating. I lost patience and replaced it with a Vetus one. Simple and effective.
If you have high water pressure on the raw water side above 3 psi your coolers or exhaust elbow could be causing this .
