Volvo Penta TMD40A oil alarm and expansion tank
Nunuwawa
4 May 2021
Hello all
I recently bought a Storebro 31 with two Volvo penta TMD40A (1980) engines.
The oil alarm (what I think it is) from one of the engines doesn't work and I cannot find a similar one anymore
Does anyone know with what/how to replace this? (12V)
Then I have another question
There is an expansion tank but I don’t understand how it supposed to work
Just under the pressure cap is an overflow outlet which is always open
How can any cool water pressure build up like this?
Thanks a lot for any advice
Walter
Leighb
8 Aug 2007
Suffolk
Welcome to SRC 31 ownership. There are two senders in the oil system, one for the pressure and the other is the alarm. There is no provision, on mine at least, for an oil temperature sender. A common problem with various of the engine circuits is a poor connection somewhere. Early on I had a scary moment when the oil pressure dropped to zero on one engine, which turned out to be a bad connection. Also the engine stop circuit failed, the button and the stop solenoid were fine, again it was the wiring in between.
it might be worth trying to make direct connection between the sender and the gauge and see if that resolves the problem? There are quite a lot of multi pin connector between the engine and the instrument panel.
Plum
6 Jun 2001
UK East Coast
Hello all
I don't know your specific engine (I have a 41) but the cap in your photo is not the pressure cap. I believe you have a pressure cap on top of the heat exchanger and, usually, the tube from there that goes to the expansion bottle you showed exits just above the main seal of the pressure cap. Above that main seal, and above where that tube exits, should be a secondary seal so that when the coolant cools it sucks what was pushed out into the expansion bottle back into the heat exchanger.
www.solocoastalsailing.co.uk
RichardS
N/A
5 Nov 2009
Home UK Midlands / Boat Croatia
This would be my assessment. If the vent pipe at the top simply connects to the air space, the pressure relief cap will be at the other end of the dip pipe which goes from the side of the tank.
Richard
VicS
13 Jul 2002
That does not seem to agree with the parts diagram which lists the cap on the expansion tank as a pressure cap and the cap on the top part of the thermostat housing as just a plain filler cap,.
The angled pipe does not appear to come from the filler cap neck so is not the overflow associated with a pressure cap.
Its unclear where the hose from the bottom of the expansion tank goes but presumably somewhere around the heat exchanger / thermostat housing which will be pressurised
I would expect the little vent pipe on the expansion tank to be sealed or for a pressure cap which seats at the bottom of the neck to be fitted
Plum
6 Jun 2001
UK East Coast
I agree its a bit of a mystery but yes, the pressure cap is in the header tank (14 ín your picture) that is directly coupled to the heat exchanger and the expansion bottle (30) has a filler cap. I was assuming hose (41) enters between the pressure seal and the secondary seal of the pressure cap. If it does not, then its definitely a mystery!
VicS
13 Jul 2002
I assume the pressure cap is similar to this one
Different shaped tank with a "vent " to the left connected back to the top of the heat exchanger ( radiator in this case)
The tank neck is plain, with no inner seat, the cap only seals on the top of the neck. If it overflows it does so all over the top of the tank... but in 40 years it has never overflowed
Plum
6 Jun 2001
UK East Coast
View attachment 115097 View attachment 115098 View attachment 115099
The pressure cap is the silver coloured one towards the front of the engine above the heat exchanger in the picture in post #9
VicS
13 Jul 2002
According to the parts description that just a filler cap. Its the one on the expansion tank which is described as a pressure cap.
Nunuwawa
4 May 2021
Thank you all
I will try to find where exactly the bottom hose from the expansion tank goes to
Regarding the oil alarm sender
Volvo has (had) a 12v and a 24v version
I thought it is just a contact but if there are two version something more is involved?
I did a little test trip yesterday and one engine overheated and I saw a lot of water
came out, will check today where it was coming from.
Also this engine made a strange metallic sound the first minutes, this suddenly stopped, strange……
The engine seemed to work normal.
Thanks again
Walter
Nunuwawa
4 May 2021
pressure cap looks just the same, only different color
RichardS
N/A
5 Nov 2009
That is definitely a pressure relief cap but I can't be sure that it has a return vacuum valve in the centre as there is no sealing ring around the central valve but it could seal against something inside the neck of the expansion tank. We would need a photo down the neck of the tank to be sure but my view is that it does not have a vacuum return as the internal boss is not sprung or deep enough and that it simply allows excess pressure out through the central valve via a drilling to one of the four side lugs.
Either way, that raises the issue in #7 about whether that small plastic pipe at the top really does go into the open air space at the top of the tank. If it is simply a vent into the open space then the cap is not doing anything at all. If it is an open vent, I wonder whether the tanks are supplied with that vent pipe sealed in the moulding which gives installers the option of drilling out the plastic depending upon the type of installation required and in your case the vent has been incorrectly opened by a previous owner?
Richard
VicS
13 Jul 2002
Richard
It definitely does have a vacuum release valve.
The centre unit can be removed and I have, many years ago, taken it apart to find out how it works, but I am not going to do so again.
VicS
13 Jul 2002
There is a little vacuum release valve (A) in the centre of the main pressure control valve
The vents ( B ) are where excess pressure is released and where air is drawn in to release the vacuum
(Modern replacements may not be the same)
RichardS
N/A
5 Nov 2009
Interesting. I did suggest that the B lugs were vented to atmosphere but I've never seen a pressure relief valve and a vacuum release valve combined into one fitting like that.
It's a clever construction which, if the little plastic tube has indeed been opened out into the expansion tank air space, is totally wasted.
I might be tempted to block off the plastic tube and see what happens.
Richard
