179580
Note item 39, the tube that screws in the expansion tank. It is quite long extending to almost the bottom of the tank. When the engine cools it will keep water in the header. Note that the parts diagram shows the pipe in the lower position but the op is in the upper position.That does not seem to agree with the parts diagram which lists the cap on the expansion tank as a pressure cap and the cap on the top part of the thermostat housing as just a plain filler cap,.
The angled pipe does not appear to come from the filler cap neck so is not the overflow associated with a pressure cap.
Its unclear where the hose from the bottom of the expansion tank goes but presumably somewhere around the heat exchanger / thermostat housing which will be pressurised
I would expect the little vent pipe on the expansion tank to be sealed or for a pressure cap which seats at the bottom of the neck to be fitted
