MLH
The trim tabs are not working and all LED lamps are flashing on the display. Does anyone have a suggestion of what the problem could be?
Yes.Are these the intercepted style tabs?
Yes.
Thank you. However, the problem is that all lights are flashing simultanously, and as far as I can see, it is not described in the manual, or what I have been able to search for.From the user manual. View attachment 95498
The problem is that all lights are flashing simultanously. I have searched the manual, but it does not describe the issue with all lights flashing.In that case my next question was going to be, which lights are flashing? As you can see from the post above, this indicates the problem.
Unfortunately, it did not workIn that case I’d try unplugging the control panel from the control unit and then recalibrate the system on reconnection. If all the lights are flashing it would appear to be all the fault codes at the same time.
ok, ThanksNot really. You could contact a dealer, the VP website is not the most helpful. Local dealer | Volvo Penta
