Volvo Penta - Low Speed Mode - Throttle Setting
CURIOUS2
14 Dec 2006
Southampton UK
I have the the above button on my throttle control lever with a single D3. It doesn’t work unless I pay My Volvo dealer to activate it. Effectively it halves the tick over revs and therefore reduces minimum boat speed by 50%. I may find this useful at my home marina which I have to lock into. When the lock is crowded a single click on the throttle tends to give to much power and makes finessing the three foot gap between boats difficult to achieve. Does anyone have experience of the VP Low Speed function and do you find it useful around marinas etc.
Elessar
10 Jul 2003
River Hamble
It's cheaper to do a day's own boat tuition. Three feet is easy!
stelican
25 Nov 2004
fareham hampshire
Sounds a useful add-on, I will be interested to read from people who have the option.
On some large engine/gearbox set ups you have the option of a trolling valve useful for tight manouvering situations and some angling practices.
Elessar
10 Jul 2003
River Hamble
Work of the devil that lets the clutch slip. I would disable it if my boat had it.
jrudge
4 Dec 2005
Live London, boat Mallorca
Cat have a button that just reduced idle rpm.
to add such a button to an electronic throttle would be easy with about £5 of bits ( switch. /wire / potentiometer ) but it seems a faf on a small boat
ss2016
24 Jul 2016
I have a D6-400 and DPI which has a 'snail'mode. I am not sure if this works the same way as yours does. When engaged the revs don't vary but the prop turns more slowly.
Is it useful in the Marina was your query I think? Well, for me, no. It engages very slowly and I find it easier for manoeuvring to just put it in gear and back out since this is almost instantaneous. It's a big push but can be very brief.
When the boat was demonstrated to me by the dealer I asked which way he manoeuvred. It transpired he also found 'snail' mode too slow to respond.
I do wonder if it might be useful in Inland waterways to avoid exceeding a speeding.
Andyroonot
28 Nov 2009
When you say it engages very slowly, do you mean there is a delay between you putting it in gear and it going in gear?
Andyroonot
28 Nov 2009
It doesn’t actually change the engine RPM, it just reduces the prop shaft RPM, or is that what you meant?
Given your description I would say it would be a useful addition in that situation although I must confess I have only ever installed it and used it briefly & my opinion is not based on long-term use.
Worth mentioning that it’s a software and hardware change unless your gearbox output flange already has the speed pick-up wheel & sensor fitted?
