A_8
Ok, I think for now forget about the SC. Looking at the video again it seems when you loosen the fuel line on the forth cylinder from the front it does not make much of a difference (or spray as much diesel as the others) to the really, really bad idle which happened with the first 3 cylinders so I would start with figurering out why that is.Hi yep supercharger is making heaps of air can’t hold your hand over the hole when you take a manafold plug out
Again, the starting and idle is not even close to what it should be and if you've fixed the wiring, the control electronics is ok and no leaks I would look closer at the injection pump.
