Lax207
Good day Folks!
Greetings from sunny Indo!
UPDATE: First of al thank you for all the inputs. It has helped so much and one of you was right- a cracked Valve Seat and an Exhaust Valve that gave it the thick black smoke during planning. We have changed all the valve seats, guides and 2 exhaust valves.
Engine runs smoke less, even during planning, however during the first start after the overhaul, the engine was on idle for 15 minutes with this ticking sound. It seems to have skipped a tooth on the timing( we checked the 2 pins on top of the valve cover and flywheel, and one of the alignment holes on the shaft was not precise). Adjusted correctly the timing, and engine purred afterwards, however still a slight ticking sound.
Sadly, after all this positive outcome so far, came the sea trial. Everything performed well, despite still the PORT engine does not accelerate quick enough as STBD (has been the main issue), but reach their top rpm’s without a hint of smoke with all parameters performing very very well. Suddenly the PORT engine creates a thump sound, decelerates, and sounding like something popped loose and giving out a leaked compression sound or like it is running only on 3 cylinders (if only I got it on video, was shooting literally 5 seconds before this happened), So, we shut engine off right away. Up to now we have not opened it up but will do so tomorrow when our mechanic is back.
My question is, during that 15 minutes idle time with the timing gear skipped a tooth, would it be enough to really damage a valve and cause it to break/fall off? Does anyone have similar experiences or any idea what it could be?
NB: We had 3 injectors replaced too and port engine really sounded ‘strong’ after the overhaul, but just the ticking sound that was still there.
Look forward for your thoughts!
Cheers,
Christopher
Cheers,
Christopher
