Lax207
Good day Folks!
Need your assistance here with a bit of an issue we have been having on our 2007 Cranchi 41' Endurance using 2x VP D6-350/DPH's with about 410 hours on both engines.
In general, both engines work just fine and reach their desired WOT as specification. A current problem we are facing is just when both engines are accelerating, the supercharger kicks in at 1500rpm and pushes the boat to 2200rpm's, and thats when the turbo takes over.
However for the port engine, it reaches 2200 rpm but then drops down to 2000 rpm as if it does not have enough boost and power to carry on. You could see on the video attached that the turbos boost is there, but as soon as it hits 2200rpm, boost and rpm goes down for a few seconds before turbo boost is built up again slowly and it continues to accelerate. During this few seconds of 'stalling' black smoke is emitted form the engine. During this stall, the starboard engine continues to perform and accelerate with no issues.
Link to video: https://drive.google.com/file/d/0B-Wh7zHONGeXVTdqcjNqbU1ZQjQ/view?usp=sharing
We have analysed everything, from checking and switching sensors, boost sensors, temperature sensors, switching the compressor, clean and trace all electrical cables for injectors to ECU, grounding, replacing air and fuel filters, inspecting turbo (compressor vane turns freely), and even had 2 injectors replaced since there was a little diesel leakage for the port engine. No diesel or water contamination on the engine oil nor have we ever had to refill the oil. In other words we do not think there is any piston or ring problems as no smoke during normal operation and does not consume any. Props, hubs has been checked and switched, so no problems there.
Do let me know your thoughts as we are baffled by this and although it is not a MAJOR issue, it would just be more satisfying to get that little hick up out of the way.
Thank you and good day!
Christopher
Christopher
