dunsnorting
Hi all. Just wondering if anyone out there can help...
I have a 2010 Fairline T38 with D4s. I had a fault on the Port Engine, which would start but not go into gear. The EVC system indicated an EVC fault and, on investigation, the shift cable was very stiff to operate. The actuator would not move, even with the shift cable disconnected, so I replaced it with a new one (£500 - ouch). With the new actuator connected but the shift cable still disconnected I have done an EVC calibration and cleared the fault code, but the new actuator still won’t move from the neutral position either ahead or astern. The green light on the EVC panel stays on when the lever is moved from the neutral position, and the status light on both HCUs is green.
The boat’s coming out of the water for new shift cables next week, but I’m keen to get the actuator working first. Grateful for any help or advice!
