poultey
The drain plug to my VP 2003 is blocked; removing it (both parts) and probing inside with a screw driver has only resulted in confirming the presence of a light grey chalkly moist sludge. Not the first time this question has been asked but the answers I can find online are not working. I need to remove the plug in order to flush any remaining water so as to not dilute the Rydlme solution I intend to soak the sludge with (engineer recommended). I've removed the anode already but I estimate there still to be 1.5 litres of water remaining below the anode hole and the top of the sludge. Introducing a tube and pumping out the water would work ( possibly through the thermostat housing) ? . . . . trying that through the anode hole has so far yielded nothing. Anything stronger than HCL acid I want to avoid - fumes in cabin etc. Any thoughts on how to disburse the sludge very welcome.
