Kylora
Hi, looking for help.
I'm helping to refit a friend's Volvo Penta 2003 back into his Westerly.
Mostly sorted, but I'm left with a cable from the alternator which I don't know where to terminate. It's the relatively heavy cable which comes from the terminal which is closest to the block. I think that would be B-. The cable has a ring terminal and the shape and length of the cable takes it somewhere near the starter solenoid.
The other heavy cable from the alternator connection furthest from the block I think is B+ and I've connected it to the top stud on the starter solenoid along with the positive cable from the battery, and a thin red cable.
The engine is shaft drive.
Background information is that the engine was removed some months ago for mechanical overhaul. The gearbox, flywheel, bellhousing, starter motor had to be stripped off to get the engine out. The engine was rebuilt on the bench and test run using temporary connections.
Ash
Ash
