RIBW
Agreed. I shortened the stubby end of a normal allen key and now keep it (labelled) on board in my 'boat special' tools box.When I took the starter off my VP2003 there was one bolt I couldn't get a hex on .......
Cheers
Bob
20 years ago I replaced a small Lister for a VP 2001 on my boat, I measured and checked the bearers for the VP, when I came to drop the engine in the GB coupling was at a strange angle and way too low.
Remeasured and checked all was fine. It was before the internet but after a few hours the penny dropped, the GB is angled down from the level by 30 degrees. New bearers made up and she fitted a treat. It ran like a little seeing machine.
Yes I soon learned thatThe engine was available with straight or angled gearboxes.
I am on board now. Taken most extra bits off. I assume i can detach at the bell housing. About 8 nuts to undo rather than at the gearbox to bell housing join which has big bolts and involves the engine/gearbox mountings.Everyone is very encouraging. Early on I got some very negative replies when I said the boat had a VP2002. Anyway I didn't get out to the boat today but I am hoping I will tomorrow. Can anyone tell me what size hex tool I need for taking off the starter motor? And I wonder what else I won't have when I come to dismantle the engine. I'll try to take some pictures to keep it all interesting.View attachment 84515
Also can anyone tell me what's the largest file size I can attach?
Hope your fuel filter is filled with diesel and you have some pressure from the fuel pump, this beast will not start otherwise. Had twice the cylinder head off off and last time with the blocked fuel line it didn't want to start at all, the trick with the canister did it. The other idea is to use an electric fuel pump. Some how the fuel line needs to have pressure....Every time when I reassembled the engine it was difficult to start....After the breakdown on the water I took the tank out and cleaned it with a high pressure washer. The dirt which came out was unbelievable... . Used an electric fuel pump to restart it. Thereafter I exchanged the fuel pump back to a mechanical again. I had the electric one in front of the mechanical because I thought the pressure was not high enough.
When every thing is order the engine starts on the first tick...
Had the valves grinded and replaced one injector. No more black smoke out of the exhaust....engine runs fine now.
Or where else can I find the 2002b manual. I need to change the Cyl head gasket on mine. (water turning oil milky, although it runs ok).
You can download the manual here - Volvo Penta Engine Workshop Service Manual
Good advice. I won't rush to throw it out.If you don't want it ... put it on eBay for $10 and see what happens. Don't throw it away, it might be exactly what someone else is looking for.
No. It's now a three cylinder Kubota.If you have another VP 2002 you now have a source of spare parts.
