Beneteau381
I would do a compression test first. Parts are available from here www.parts4engines.comHi folks. Newby here. My son has bought a yacht with a Volvo Penta 2002 engine. It doesn't start and whenever I talk to a professional all they can say is "bin it". That's all very well but I like to persevere with things until I am driven insane (maybe I'm there). My son spent all his money buying the boat and intends to save for a new engine but that may be a while off and so, if we can get a bit of life out of this one then it will make getting on and off the mooring a lot easier (and safer).
So far we've worked our way down the list of easier things and our current conclusion is that there is not enough compression. The head seems fine. We've had it off and lapped the valves and given it a good look over and it looks OK. The injectors seem to squirt ok and from the top, the cylinders and pistons don't appear to have any major damage. I put some oil in the cylinders and it fired just a bit on turnover but then went dead again, so I am guessing the problem might be the rings. Next step is the pull the pistons out and here is where I start asking questions of those with more experience than I have. The boat is an S & S 34 DEB33 variant and access to the engine is pretty good by yacht standards. I'm wondering if I can disconnect the engine from the gearbox, pull it forward a bit and roll it on its side. Then remove the sump/pan and pistons in that position. Has anybody done this and what unforeseen problems are likely to occur?
