VicS
Or an alternator wiring issue somehow back feeding voltage when not running, as I understand from recent panel mods of my own the buzzer takes it's power from the alternator field coil (which should be grounded through it's own winding when not running) to stop it buzzing before the engine starts, once the alternator is activated the alarm buzzer has it's power, one of the diodes in the circuit diagram is a zener diode but not properly shown as such.
It's definately getting power from somewhere before the switch is turned on.
I am thinking along similar lines . . . . Back feeing from the alternator via the warning light circuit.
However this would need a backwards flow though the main rectifier from the battery. This would not normally occur but the rectifier may have damaged by the bad battery connection issue.
It would explain the buzzer sounding but not the warning lights being illuminate AFAICS unless there was also damage to components in the module . . . most likely to the transistor ??????
This schematic diagram of the electronic module is easier to follow than the one in the manual
