Plevier
I have a 2003 Volvo MD2020D in a 31 ft boat, total engine hours from new 445 so quite young. Fitted with a Kiwi Prop pitched for 3400rpm at WOT under way. Normally I use 2200-2500 cruising rpm, occasionally more for a cleanout. Never had overheating.
On Saturday afternoon we were trying to go from Beaulieu to Lymington into 30kts wind and 3kts tide. (You can tell we don't know the Solent well.) I was using more revs than normal, about 3000. After a while the engine high temp alarm went off and on investigation about 1.5L of coolant was in the tray under the engine.
Cautiously refilled with hot water, no boiling off when doing that so the engine wasn't terribly hot. All seemed OK. Carried on (slowly!) at 2500rpm then after a while increased to 2700 then 2900. A bit later it happened again, alarm went and there was bubbly water/steam mixture coming from the header tank overflow pipe.
Refilled and carried on a bit slower and finally got there.
Next morning I took out the heat exchanger to clean, it was fine. All the seawater side is good, lots of flow and the exhaust elbow, pipe and water trap are cold. Feeling the calorifier hoses when running at 2500rpm they are pretty hot to touch but not boiling hot and you can just about keep your hand on the engine header tank, so I think the 'stat (operating range 75-87 deg C) is OK.
So I can find nothing wrong. Have done several hours since then at lower power with no problems.
I thought an engine like this would be configured so it would run indefinitely at high power without overheating, particularly in a cool climate. Am I wrong?
Has anyone had similar experience or any ideas of potential problems please?
The engine has always had a/freeze with inhibitors in it, there's no reason to expect sludge in the cylinder block. I changed the a/f 2 years ago and tried to drain and flush the engine but couldn't undo the dreadful square headed cast iron drain plug on the block so couldn't flush. Anyone got any tips on getting the little so and so out? You can't get a spanner near it and a hex socket just rounds the corners; is it possible to get a square socket to fit it?
